RG-CS86-20XS4VS2QXS-D 20-Port 10GE Layer 3 Ruijie Cloud-Managed Core/Aggregation Switch (4 x 25GE SFP28 Ports, 10GE Compatible), 40GE Uplink
Suitable for SME network core and large-scale network aggregation
  • 20 x 10GE SFP+ ports, 4 x 25GE SFP28 ports, and 2 x 40GE QSFP+ ports for uplink
and Network Connectivity
Fixed Ports
20 x 1G/10G SFP+ ports, 4 x 10G/25G SFP28 ports, 2 x 40G QSFP+ ports. One switch provides a maximum of 32 x 10G ports, 2 modular power slots, and 2 modular fan slots.
Fan modules
Dual pluggable modular fans, with front-to-rear ventilation channels
Power modules
2 replaceable hot-swappable power supply slots
One MGMT port, one console port, and one USB port
Forwarding Rate
570 Mpps
 760 Gbps/2.56 Tbps
MAC Table Capacity
32,768
IPv4 Unicast Routes
IPv4 Multicast Routes
IPv6 Unicast Routes
IPv6 Multicast Routes
In: 2,500
Out:1,000
440 x 330 x 43.6 mm (17.32 x 12.99 x 1.72 in), 1 RU
Weight of the empty chassis
4.6 kg (10.14 lbs)
Dual-core CPU, 1.25GHz
Flash memory: 1 GB
SDRAM: 1 GB
Supported power module type: RG-PA150I-F
Maximum voltage range: 90–264 V AC; 47/63 Hz
Rated input current: 3 A
Rated voltage: 240 V DC
Maximum voltage range: 192–288 V AC
Power port: 6 kV/6 kV
Temperature Alarm
Software S
pecifications
Telnet
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10G/25G SFP28 ports, 2 x 40G QSFP+ ports, supports up to 32×10G ports, 2 slots for power supply module, requires at least one RG-PA150I-F power supply module, 2 slots for fan modules, 2 pre-installed fans (Purchase at least one RG-PA150I-F module.)
150W AC power supply module for RG-CS86-20XS4VS2QXS-D
1000BASE-GT mini GBIC conversion module
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 300m
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 10km
10G SP fiber module, applicable to SFP+ ports, max cabling distance: 40km
25G fiber module
25G fiber module
10G SFP+ connector fiber, 1m long, including one cable and two connector modules
10G SFP+ connector fiber, 3m long, including one cable and two connector modules
10G SFP+ connector fiber, 5m long, including one cable and two connector modules
25G Base SFP+ fiber cable (including modules on both ends), 5m long
40G SR fiber module, applicable to QSFP+ ports (OM3/OM4 MPO interface, 8 core, 850nm wave length, max cabling distance: 100m(OM3), 150m(OM4))
40G LR single-mode fiber module, applicable to QSFP+ ports, max cabling distance:10km (LC interface, 2 core, 1310nm wave length)
40G QSFP+ connector fiber, 5m long, including one cable and two connector modules
40G QSFP+ connector fiber, 10m long, including one cable and two connector modules
