RG-S6920-4C Switch - 1
RG-S6920-4C Switch - 2
RG-S6920-4C Switch - 3
RG-S6920-4C Switch - 4
RG-S6920-4C Switch - 5
RG-S6920-4C Switch - 6
RG-S6920-4C Switch - 7
and Zero Packet Loss
RG-S6920-4C
100GE/400GE ports
Expansion Module Slots
Four power modules
Six fan modules
25.6 Tbps
8,000 Mpps
4,094
(W × D × H)
Maximum Power Consumption
● Max: 1,950 W
● Typical: 1,469 W
● Static: 516 W
AC
RG-PA1200I-F
High-Voltage DC
RG-S6920-4C
Layer 3 Protocols (IPv4)
IPv6 Protocols
Data Center Features
PFC and ECN
M-LAG
RDMA
OpenFlow 1.3
BGP-EVPN
* AI ECN
* ECN Overlay
INT
802.1p, DSCP, and ToS mapping
High Availability Design
Security Features
Management Mode
Specification
RG-S6920-4C
● EN IEC 62368-1
● BS EN IEC 62368-1
● UL 62368-1
● CSA C22.2#62368-1
● EN IEC 61000-3-3
● ETSI EN 300 386
● EN 300 386
● ICES-003 Issue 7
● ICES-003 Issue 6
● ANSI C63.4-2014
● AS/NZS CISPR 32
● CISPR 32
RG-S6920-4C
RG-PA1200I-F
M2EFAN I-F
M6900-32CQ
M6900-16CQ4QC
M6900-08QC
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
400G-QDD-SR8-MM850
400G-QDD-AOCxM
200G-Q56-SR4-MM850(D)
