RG-S5000-48GT4MS-E Switch - 1
RG-S5000-48GT4MS-E Switch - 2
RG-S5000-48GT4MS-E Switch - 3
RG-S5000-48GT4MS-E Switch - 4
RG-S5000-48GT4MS-E Switch - 5
RG-S5000-48GT4MS-E Switch - 6
RG-S5000-48GT4MS-E Switch - 7
RG-S5000-48GT4MS-E Switch - 8
RG-S5000-48GT4MS-E Switch - 9
RG-S5000-48GT4MS-E Switch - 10
RG-S5000-48GT4MS-E Switch - 11
RG-S5000-48GT4MS-E
Switching capacity: 116 Gbps
Forwarding rate: 87 Mpps
Local & Cloud O&M
Visualized Management
Alarm Processing
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
RG-S5000-10GT2MS-P-E
RG-S5000-24GT4MS-P-E
10 x 10/100/1000BASE-T ports
2 x 1GE/2.5GE SFP ports
4 x 1GE/2.5GE SFP ports
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
27 Mpps
104 Mpps
27 Mpps
139 Gbps
64 MB
64 MB
64 MB
64 MB
64 MB
DDR4 512 MB
DDR4 512 MB
DDR4 512 MB
DDR4 512 MB
DDR4 512 MB
256
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
260 mm x 170 mm x 43.6 mm (10.24 in. x 6.69 in. x 1.72 in.)
440 mm x 220 mm x 43.6 mm (17.32 in. x 8.66 in. x 1.72 in.)
297 mm x 170 mm x 43.6 mm (11.69 in. x 6.69 in. x 1.72 in.)
2.0 kg (4.41 lbs)
2.40 kg (5.25 lbs)
3.70 kg (8.15 lbs)
3.60 kg (7.94 lbs)
3.18 kg (7.01 lbs)
4.13 kg (9.11 lbs)
Mounting
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
Fixed power supply: 16 W
Fixed power supply: 15.6 W
Fixed power supply: 30 W
Fixed power supply: 141 W
Fixed power supply: 430 W
16 W
16 W (without PoE load)
141 W (full PoE load)
33 W (without PoE load)
403 W (full PoE load)
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
27℃ (80.6°F): 40 dB
27℃ (80.6°F): 40 dB
27℃ (80.6°F): 40 dB
Air discharge: 8 kV/15 kV
Contact discharge: 6 kV/8 kV
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
RG-S5000-E Series
Port-based VLAN assignment
Basic QinQ and selective QinQ
DNS client
Neighbor Discovery (ND)
Expert ACLs
Port rate limiting
IEEE 802.1X authentication
Proxy ARP and ARP entry aging
Hardware CPP and NFPP
Load balancing modes
TFTP (TFTP client)
SSH v1.5/v2.0
l IEEE 802.3af and 802.3at
l Port priority
Cloud
WIS
RG-S5000-10GT2MS-E
RG-S5000-24GT4MS-E
RG-S5000-48GT4MS-E
