48 x 5GE Ethernet ports, 4 x 25GE SFP28 ports, 2 x 40GE QSFP+ ports
RG-CS86-12XMG4VS-UP12 x 10GE Ethernet ports, 4 x 25GE SFP28 ports
RG-CS86-24MG4VS-UP |
RG-CS86-48MG4VS2QXS-UPD |
RG-CS86-24XMG4XS4VS-UPD |
RG-CS86-12XMG4VS-UP |
Fixed port |
Fan module |
2 fixed fans |
3 modular fans |
3 modular fans |
2 fixed fans |
Power module |
1 Built-in power module |
Fixed management port |
Packet forwarding rate |
327 Mpps |
625 Mpps |
565 Mpps |
327 Mpps |
Switching capacity |
440 Gbps |
840 Gbps |
760Gbps |
440 Gbps |
MAC address table size |
32,768 |
16,000 |
16,000 |
4,000 |
16,000 |
2,000 |
Ingress: 2,500 Egress:1,000 |
Number of VSU members |
2 |
3.65 kg (8.82 lbs) |
6.11 kg (13.47 lbs) |
3.65 kg (8.82 lbs.) |
ARM processor, 1.25 GHz |
Flash memory |
1 GB |
1 GB |
1 GB |
1 GB |
BootROM |
16 MB |
16 MB |
16 MB |
16 MB |
SDRAM |
1 GB |
1 GB |
1 GB |
1 GB |
Data packet buffer |
4 MB |
4 MB |
4 MB |
4 MB |
Maximum output power |
460W |
460W |
Rated Input Voltage |
PoE-capable Port |
22.18 years |
27.02 years |
22.18 years |
22.18 years |
Primary airflow |
Front/Left-to-rear airflow |
Operating Temperature |
0°C to 45°C (32°F to 113°F) |
Storage Temperature |
Operating Humidity |
Storage Humidity |
Surge Protection |
6 kV |
6 kV |
6 kV |
6 kV |
Temperature Monitoring |
Temperature alarm |
Temperature alarm |
Temperature alarm |
Temperature alarm |
Software Specifications |
Ethernet switching |
Super VLAN, Private VLAN |
Basic QinQ Flexible QinQ |
STP, RSTP, and MSTP |
LACP (IEEE 802.3ad) |
IP service |
ARP |
DHCP snooping |
DHCPv6 snooping |
IP Routing |
BGP4 and BGP4+ |
IPv4 and IPv6 PBR |
ECMP |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD v1/v2 |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
Port traffic rate limiting |
Multiple AAA modes |
RADIUS and TACAS+ |
HTTPS |
SSHv1, SSHv2 |
Global IP-MAC binding |
SAVI |
REUP, RLDP, DLDP |
BFD |
GR for RIP, OSPF, BGP |
1+1 power redundancy |
SPAN, RSPAN, and ERSPAN |
sFLOW |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
Cloud and SON |
RG-PA600I-P-F |
600 W AC power module |
RG-PA1000I-P-F |
1000 W AC power module |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
VG-SFP-SR-MM850 |
VG-SFP-LR-SM1310 |
VG-SFP-AOC5M |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4 SM1310 |
40G-AOC-5M |
40G-AOC-10M |
