RG-S5310-24GT4XS-P-E 24-Port GE Electrical Layer 3 Managed Access Switch with PoE+, Four 10G Uplink Ports
  • RG-S5310-E Series
Service port
24x 10/100/1000
BASE-T ports 4x 1G/10G SFP+ ports Supports PoE Standards IEEE 802.3af, 802.3at
Power Supplies
1+1 power supply
backup Up to 720w of PoE+
Forwarding rate
126Mpps
442 mm × 420 mm × 43.6 mm
0 - 45°C
1 MGMT port, 1 console port, and 1 USB port, compliant with USB2.0 standard
3.36Tbps
<85W(Non POE)
<810W (PoE full load)
Flash Memory
2GB
Warranty duration
3 years
Full-gigabit access switch for large-sized enterprise and campus LANs, with four 10G uplink optical ports for high-speed data transmission 24 x 1000 Mbps Ethernet ports with auto-negotiation, PoE+ supported, providing high-speed network experience for short-distance services
What does the letter E in RG-S5310-24GT4XS-E mean?
E in the model name means that this is an enhanced model in this series.
118
What power modules should I buy for an RG-S5310-E series GE switch?
When selecting a power module, the first thing is to check the power consumption of the switch. If dual power modules are used for power redundancy, the power of a single power module must be greater than the power consumption of the switch. Taking the RG-S5310-24GT4XS-E switch as an example, the power consumption is ≤ 40W. You can purchase the RG-PA70IB power module for this switch.
Below lists some power module models and their description:
RG-PA70IB: 70W AC power module
RG-PA150IB-F: 150W AC power module
RG-PD150IB-F: 150W DC power module
RG-PA600I-P-F: 600W AC power module, PoE supported
RG-PA1000I-P-F: 1000W AC power module, PoE supported
170
How is loop detection realized in this series?
This series adopts the Rapid Link Detection Protocol (RLDP), a link detection protocol independently developed by Ruijie Networks for rapid detection of Ethernet link failures.
Most Ethernet link detection mechanisms detect link connectivity through auto negotiation of the physical layer based on the state of the physical connection.
However, this type of link detection mechanism has certain limitations. In some cases, it cannot provide users with reliable link detection information. For example, when the Tx and Rx ends of a fiber optic cable are incorrectly connected to an optical port, due to the existence of an optical fiber converter, the link on the port is still physically up, but in fact communication on the layer 2 link is off. Another example is that if there is an intermediate network between two Ethernet devices, due to the existence of a relay device on the network, the same problem will occur if the relay device fails.
With RLDP, users can easily and quickly detect a link failure on an Ethernet device, including unidirectional, bidirectional, and loop link failures.
291
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS -E
RG-S5310-48GT4XS-P-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
24 x 10/100/1000 BASE-T ports
4 x 1G/10G SFP+ ports
48 x 10/100/1000 BASE-T ports
24 x 1000M SFP ports
48 x 1000M SFP ports
Management port
131 Mpps
131 Mpps
131 Mpps
4k/16k (authorized)
2k/8k (authorized)
8k/12k (authorized)
4.2 kg (9.26 lbs)
4.6 kg (10.14 lbs)
4.2 kg (9.26 lbs)
4.5 kg (9.92 lbs. )
1.2 GHz dual-core processor
BOOTROM
Flash
≤ 40 W
< 85 W (non-PoE)
< 810 W (PoE full load)
≤ 55 W
< 75 W (non-PoE)
< 1,570 W (PoE full load)
≤ 85 W
≤ 108 W
RG-PA70IB: 70 W
RG-PA150IB-F: 150 W
RG-PD150IB-F: 150 W
RG-PA70IB: 70 W
RG-PA150IB-F: 150 W
RG-PD150IB-F: 150 W
RG-PA70IB: 70 W
RG-PA150IB-F: 150 W
RG-PD150IB-F: 150 W
RG-PA150IB-F: 150 W
RG-PD150IB-F: 150 W
Left/Front-to-rear airflow
< 56.5 dB
< 57.4 dB
< 52.4 dB
< 58.3 dB
< 53.7 dB
< 53.7 dB
RG-S5310-E Series
OSPFv2, OSPFv3, and GR
Basic LACP
Inter-VSU AP
Hot swapping of power modules
RSPAN and ERSPAN
CLI (Telnet/Console)
1:1 mirroring
N:1 mirroring
1:N mirroring
VXLAN (authorized)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-PA70IB
70 W AC power module
RG-VXLAN-MPLS-ENTRY-LIC
TOP
