RG-S6580-24DC8QC Switch - 1
RG-S6580-24DC8QC Switch - 2
RG-S6580-24DC8QC Switch - 3
RG-S6580-24DC8QC Switch - 4
RG-S6580-24DC8QC Switch - 5
RG-S6580-24DC8QC Switch - 6
RG-S6580-24DC8QC Switch - 7
RG-S6580-24DC8QC Switch - 8
RG-S6580-24DC8QC Switch - 9
RG-S6580-24DC8QC Switch - 10
RG-S6580-24DC8QC – Next-Generation Data Center 200GE Fixed Access Switch, 400GE Uplink (Backward Compatible with 100GE)
200GE access switch (one 200GE port split into two 100GE ports), and 400GE ZR/ZR+ optical modules for interconnection at the maximum distance of 120 km
  • Various ports - 24 x 200GE QSPF56 ports and 8 x 400GE QSPF-DD ports, allowing flexible networking
Data Center 200GE Access Switch RG-S6580-24DC8QC
Data center 200GE access switch with 1 RU, various ports, improved data forwarding capability,
and flexible scenario deployment200GE/100GE server access and evolution to 100GE/400GE data center networks
Power modules in 1+1 redundancy mode, failover in seconds, and power module replacement without network interruption, providing double protection for links
and Zero Packet Loss
With RDMA technology, data does not need to be handled by the CPU during device communication. This reduces the CPU
burden and effectively solves the network latency problem.
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
48 × 100GE ports (DSFP) + 8 × 400GE ports (QSFP-DD)
24 × 200GE ports (QSFP56) + 8 × 400GE ports (QSFP-DD)
Expansion Module Slots
Two power supply module slots (1+1 redundancy)
Six fan module slots (5+1 redundancy; at least 5 fan modules are required)
16.0 Tbps
5350 Mpps
4094
Dimensions (W × D × H)
442 mm x 700 mm x 44 mm (17.40 in. x 27.56 in. x 1.73 in., 1 RU)
442 mm x 670.8 mm x 43.6 mm (17.40 in. x 26.41 in. x 1.72 in., 1 RU)
Chassis with six fan modules and two power supply modules: 11.5 kg (25.35 lbs.)
Chassis with six fan modules and two power supply modules: 11 kg (24.25 lbs.)
Power Input
RG-PA1200I-F module
● Rated voltage range: 100 V AC to 127 V AC (50 Hz to 60 Hz), rated current: 13.8 A
● Rated voltage range: 200 V AC to 240 V AC (50 Hz to 60 Hz), rated current: 8.5 A
HVDC input
RG-PA1200I-F module
● Rated voltage: 240 V DC
● Max voltage range: 180 V DC to 300 V DC
● Max input current: 6.5 A
Maximum Power Consumption
● Max: 742 W
● Typical: 633 W
● Static: 178 W
● Max: 850 W
● Typical: 700 W
● Static: 300 W
Temperature Alarm
Temperature alarms and overheat protection
10% RH to 90% RH (non-condensing)
Working altitude
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
L2 Protocols
IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB)
L3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, LPM routing, Policy-based Routing (PBR), route-policy, Equal-Cost Multi-Path Routing (ECMP), WCMP, VRRP
IPv6 Basic Protocols
ACL 80、ACL-based Redirection、IPv6 ACL、Extended/Standard IP/MAC-based ACL、Time-based ACL、Global ACL、When an ACL is applied to different physical interfaces or SVIs, resources can be shared.、ACL Counter、ACL Counter Only、ACL Logging、Diplaying ACL Resource Usage、Expert-level ACL、IPv4 UDF ACL、Global ACL Counter Only、Matching Against the Inner 5-Tuple of the VXLAN、IPv6 UDF ACL、Matching Against the Inner 5-Tuple of the Passing VXLAN、Ingress/Egress ACLs
ACL80、ACL-based redirection、IPv6 ACL、Extended/Standard IP ACL、Extended MAC ACL、Time-based ACL、Global ACL、Resource sharing in the case of applying an ACL on different physical ports or SVIs、ACL counter、ACL counter only、ACL logging、Displaying ACL resource usage、ACL-based re-marking、Expert-level ACL、IPv4 user-defined function(UDF) ACL、Configuring ACL counter-only globally、ACL matching against the inner 5-tuple of VXLAN packets、IPv6 UDF ACL、ACL matching against the inner 5-tuple of packets passing through the VXLAN
Data Center Features
RDMA
sFlow sampling
HA Design
Security Features
Network foundation protection policy (NFPP), CPP, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, broadcast packet suppression, hierarchical user management
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm
DHCP client, DHCP relay, DHCP server, DNS client, ARP proxy, and Syslog
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
● BS EN 62368-1
● BS EN 55032
● BS EN 55035
● EN 61000-3-2
● BS EN 61000-3-2
● BS EN 61000-3-3
● EN 300 386
● VCCI-CISPR 32:2016
  • Select the switch (installed with all fan and power supply modules).
Chassis, Fan Module
RG-S6580-48CQ8QC
48 × 100GE DSFP ports + 8 × 400GE QSFP-DD ports
Two power slots and six fan slots
The chassis is installed with two RG-PA1200I-F modules and six M1HFAN II-F fan modules.
RG-S6580-24DC8QC
24 × 200GE QSFP56 ports + 8 × 400GE QSFP-DD ports
Power Supply Module
RG-PA1200I-F
1200 W AC module (AC/240 V HVDC)
Fan Module
M1HFAN II-F
Fan module (front-to-rear ventilation)
400G-QDD-SR8-MM850
400G SR8 module, QSFP-DD form factor, MPO-16 APC, 850 nm, 100 m (328.08 ft.) over MMF
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
