RG-S5760C-24GT8XS-X Switch - 1
RG-S5760C-24GT8XS-X Switch - 2
RG-S5760C-24GT8XS-X Switch - 3
RG-S5760C-24GT8XS-X Switch - 4
RG-S5760C-24GT8XS-X Switch - 5
RG-S5760C-24GT8XS-X Switch - 6
RG-S5760C-24GT8XS-X Switch - 7
RG-S5760C-24GT8XS-X Switch - 8
RG-S5760C-24GT8XS-X Switch - 9
RG-S5760C-24GT8XS-X Switch - 10
RG-S5760C-24GT8XS-X Switch - 11
RG-S5760C-24GT8XS-X Switch - 12
RG-S5760C-24GT8XS-X 24-Port Layer 3 Enterprise-Class Core or Aggregation Switch, 8-Port 10GE Uplink
  • Rich port types, 24 x 10/100/1000BASE-T ports for access, and 8 x 1GE/10GE SFP+ ports for uplink
Aggregation switch for small and medium-sized campus networks, with 8 x 1GE/10GE SFP+ uplink ports for high-speed data transmission; 24 x 10/100/1000BASE-T ports, providing high-speed network experience for short-distance services. Core switch for small and medium-sized enterprise networks, with high scalability, efficiency, and manageability, and device-level and link-level reliabilities for stable connectivity.
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
RG-S5760C-24SFP/8GT8XS-X
RG-S5760C-48SFP4XS-X
RG-S5760C-48GT4XS-HP-X
48 x 10/100/1000BAST-T ports
24 x 1GE SFP ports
M5000X-4XS2CQ
RG-PD150IB-F
RG-PD150IB-F
RG-PD150IB-F
RG-PD150IB-F
Not Supported
Not Supported
Not Supported
M2SFAN I-F (pre-installed 2)
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
614 Mpps
586 Mpps
614 Mpps
586 Mpps
586 Mpps
826 Gbps
787 Gbps
826 Gbps
787 Gbps
787 Gbps
4 GB eMMC
2 GB
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
RG-PA150IB-F (AC input):
RG-PD150IB-F (DC input):
RG-PD150IB-F: 150 W
● 2 x RG-PA600I-P-F: 740 W
120 W (without PoE load)
1,600 W (full PoE load)
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
4.4 kg (9.70 lbs)
5.3 kg (11.68 lbs)
5.5 kg (12.13 lbs)
6.20 kg (13.67 lbs)
6.30 kg (13.89 lbs)
6.30 kg (13.89 lbs)
7.80 kg (17.20 lbs)
7.70kg (16.98 lbs)
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
2 x pluggable fan modules
27°C (80.6°F): 50 dB
45°C (113°F): 65 dB
27°C (80.6°F): 53 dB
45°C (113°F): 68 dB
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
RG-S5760C-X Series
IGMP v1/v2/v3 and IGMP proxy
Dynamic ARP Inspection (DAI)
REUP, RLDP, and DLDP
1+1 power module redundancy
Syslog
RG-S5760C-48GT4XS-HP-E:
RG-S5760C-24GT8XS-X
RG-S5760C-48GT4XS-X
RG-PD150IB-F
150 W DC power module
M5000X-4XS2CQ
