RG-S2915-10GT2MS-P-L Switch - 1
RG-S2915-10GT2MS-P-L Switch - 2
RG-S2915-10GT2MS-P-L Switch - 3
RG-S2915-10GT2MS-P-L Switch - 4
RG-S2915-10GT2MS-P-L Switch - 5
RG-S2915-10GT2MS-P-L Switch - 6
RG-S2915-10GT2MS-P-L Switch - 7
RG-S2915-10GT2MS-P-L Switch - 8
RG-S2915-10GT2MS-P-L Switch - 9
RG-S2915-10GT2MS-P-L Switch - 10
RG-S2915-10GT2MS-P-L Switch - 11
Killer Layer 2+ Access Switch
Applications
and Uninterrupted Connection
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
RG-S2915-24GT4MS-P-L
Fixed Service Ports
48 × 10/100/1000BASE-T ports, 4 × 1GE/2.5GE SFP ports
24 × 10/100/1000BASE-T ports, 4 × 1GE/2.5GE SFP ports
24 ×
10 × 10/100/1000BASE-T ports, ports 1 to 8 supporting PoE/PoE+,
2 × 1GE/2.5GE SFP ports
Power modules
1 fixed power module
Fans modules
2 fixed fans
2 fixed fans
1 fixed fans
116Gbps
68Gbps
68Gbps
30Gbps
MAC Table Capacity
Flash Memory
64 MB
< 30 W
< 15.6 W
< 33 W (non-PoE)
< 403 W (PoE full load)
< 16 W (non-PoE)
< 141 W (PoE full load)
≤ 37 dB
≤ 39 dB
≤ 37 dB
Power port: 6 kV/2 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
IEEE 802.1Q (4,094 VLANs)
Port based VLAN
SSHv1, SSHv2
IGMP V1,V2 snooping
Temperature Monitoring
Temperature Alarm
Overtemperature Protection
TFTP client
RG-S2915-48GT4MS-L
48 × 10/100/1000BASE-T ports, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply
RG-S2915-24GT4MS-L
24 × 10/100/1000BASE-T ports, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply
24 × 10/100/1000BASE-T ports, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, 370 W PoE power supply
10 × 10/100/1000BASE-T ports, 2 × 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, 125 W PoE power supply
