High-density 200GE fixed switch, support for 200GE optical transceivers
System |
RG-S6980-128DC |
Ports |
128 x 200GE ports (QSFP56) |
Expansion Modules |
Not supported |
Power Modules |
Four power module slots, supporting 2+2 redundancy |
Fan Modules |
Eight fan module slots, supporting 7+1 redundancy |
Management Ports |
Switching Capacity |
51.2 Tbps |
Packet Forwarding Rate |
10,300 Mpps |
442 mm x 760 mm x 175 mm (17.40 in. x 29.92 in. x 6.89 in., 4 RU) |
Net Weight |
39.65 kg (87.41 lbs., including eight fan modules and four power modules) |
Maximum Power Consumption |
2,550 W |
AC |
AC input: Rated voltage range: 100 V AC to 127 V AC Frequency: 50 Hz to 60 Hz Maximum rated input current: 12 A Rated voltage range: 200 V AC to 240 V AC Frequency: 50 Hz to 60 Hz Maximum rated input current: 8 A |
High-Voltage DC |
Voltage: 240 V DC Maximum rated input current: 6.5 A |
0°C to 40°C (32°F to 104°F) |
Altitude |
0 m to 1,800 m (0 ft. to 5,905.51 ft.) |
Software Specifications |
RG-S6980-128DC |
Layer 2 Protocols |
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), jumbo frame (9 KB) |
IPv4 Features |
BGP4, OSPFv2, RIPv1, RIPv2, LPM routing, PBR, routing policy, ECMP, WCMP, VRRP |
IPv6 Features |
Neighbor discovery, ICMPv6, path MTU discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMPv6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, IPv6 QoS, static routing, ECMP routing, PBR, OSPFv3, RIPng, BGP4+ |
Data Center Features |
PFC, ECN RDMA VXLAN, BGP-EVPN PFC deadlock prevention * AI ECN * ECN overlay RALB, AILB |
Visualization |
Collecting data including basic switch information, real-time RoCE buffer state, interface-based QoS queue and real-time interface utilization, ECN and PFC events, and media side SNR* through telemetry gRPC sFlow |
QoS |
802.1p, DSCP, and ToS mapping ACL-based traffic classification |
Hgh Availability Design |
GR for RIP/OSPF/BGP, BFD, REUP, Rapid Link Detection Protocol (RLDP), 2+2 power redundancy, fan redundancy, and hot swappable line cards and power modules |
Security Features |
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, broadcast packet suppression, and hierarchical user management |
Management Mode |
SNMP v1/v2/v3, Telnet, console, MGMT, RMON, SSH v1/v2, FTP/TFTP, NTP, syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and overheat alarm |
Other Protocols |
DHCP client, DHCP relay, DHCP server, DNS client, proxy ARP, and syslog |
RG-S6980-128DC |
128 x 200GE ports, four power module slots, eight fan module slots |
PSA1300CRPS-F-RJ |
Hot swappable power module, 2+2 redundancy, and front-to-rear airflow |
FAN12K8080-F-RJ |
Hot swappable fan module, 7+1 redundancy, and front-to-rear airflow |
100G-QSFP-iLR4-SM1310 |
100G iLR4 transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 2 km (6,561.68 ft.) over SMF |
100G-QSFP-LR4-SM1310 |
100G LR4 transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 10 km (32,808.40 ft.) over SMF |
100G-QSFP-SR-MM850 |
100G SR transceiver, QSFP28 form factor, MPO, 850 nm, 100 m (328.08 ft.) over MMF |
100G-QSFP-ER4-SM1310 |
100G ER4 transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 40 km (131,233.59 ft.) over SMF |
100G-AOC-1M |
100G AOC cable, QSFP28 form factor, 1 m (3.28 ft.) |
100G-AOC-5M |
100G AOC cable, QSFP28 form factor, 5 m (16.40 ft.) |
100G-AOC-10M |
100G AOC cable, QSFP28 form factor, 10 m (32.81 ft.) |
200G-Q56-SR4-MM850(D) |
200G SR4 transceiver, QSFP56 form factor, MPO-12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MMF, in compliance with CMIS, applied to the switch side. |
200G-Q56-SR4-MM850 |
200G SR4 transceiver, QSFP56 form factor, MPO-12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MMF, in compliance with SFF-8636, applied to the server side. |
